Is that a banshee trans or streetbike trans that matches the cases? Dont remember the inner casting in the trans area on banshee cases. Does a banshee ratio even fit in there?
You should research them a little more before selling. I believe them to be from a streetbike of some vintage due to the tach drive. I also believe the trans ratios are different. I highly recomend you figure out what your selling before it sells to avoid problems from false advertising. plus it will be a good learning experience
Quick research shows you most likely have a rz350 case. Looking at the drum and forks they appear to be rz also. I guess the forks have rollers instead of pins that follow the drum. Best bet is to count teeth on the gears and confirm exact trans ratios. Asphalt guys might be interested in these.
