SiCkBaNsHeE_990 Posted November 17, 2003 Report Share Posted November 17, 2003 I just got this used and it came with no instrustions. I was wonder if anyone could give me detailed instrustion on how to wire it up. What to disconnect and what goes where. Please help!!! Thanks Quote Link to comment Share on other sites More sharing options...
txblueshee Posted November 17, 2003 Report Share Posted November 17, 2003 Cut your positive wire (orange) that runs into your ignition box(up under right front fender) about 4'' away from were it connects, then strip about 1.5-2'' off each side of the cut positive wire, then strip 2'' off the positive (shorter) teather switch wire, twist all 3 of the positive connections together (or solder), crimp-on butt connecter over the connections, then plug the connection back into the ignition box(after you hook up the ground). Then Take the longer wire(ground),strip about 2''off of it, loosen your right/left (depending on which side you put the teather on) header bracket bolt, place the stripped part behind it and tighten back up. Have any other questions just ask, pm or IM me. Mike Quote Link to comment Share on other sites More sharing options...
SICK BOY Posted November 17, 2003 Report Share Posted November 17, 2003 I spliced one wire to the orange wire one the coil and grounded the other.You com get a step by step for free at WWW.BLUETRAXX.COM . Quote Link to comment Share on other sites More sharing options...
