Well, since I've never had anything PC'd b4 I'm hoping someone can Gove me some advice on prepping so I get the best job. I'm in the process of cutting off unneeded tabs at the moment and I got a bracket grin SD customs to move my stator and coolant bottle up front. Any other suggestions?
Sent from my SCH-I535 using Tapatalk
F'n auto correct. Anyway, I'm also taking all the tabs off for the front brakes and going with aftermarket lines and brackets on the a-arms.
Yeah,  I got all the welding spatter off but I think that would've come off when the sand blaster hit it.  These are the two best leads I've gotten:
Taking care of the VIN (from Starwriter)
http://bansheehq.com/forums/index.php?showtopic=177212&p=1632336
Tabs and a convenient to-do-list;
http://bansheehq.com/forums/index.php?showtopic=171188&page=1
Edited by muggzy
go to cascades webbsite  look at all the nice and closeup frame modifications..
cut off the rear subframe exhaust mounts, stuff if you dont need it.  the rear foot peg guards if you dont need it. and add the front sterring stop reinforcement.   you cannot powdercoat stock a-arms.  have them plug all threaded holes and after you get it back run a tap through every single hole.    make sure they also plug where the swingarm bolt goes through and the front lower steering stem bearing area and threads.
