03 Banshee Top End Cleaning & Buying new Carbs
Not really sure what you are asking? You asking what you can use to clean the gasket surface?? If you are looking to flush the cases out where the crank is you need to take the motor out so you can dump out whatever it is you use to flush it out.
Use a razor blade to scrape off the old gasket and the either a scotch brite pad or some really fine sand paper to really polish it up nice and clean
If your not planning on making big power then do a little research...stock carbs are plenty fine up into the 60's horsepower wise...save your money on that and spend it on suspension if it doesnt already have it...my .02
  • Like 1
