buckdeezy88 Posted June 19, 2014 Report Posted June 19, 2014 ive replaced the stator cdi stator rectifier kill switch and key switch im not sure how I can test to see whats wrong I bought a multi meter but im not too sure how to use it or what im looking for if possible someone please help me Quote
fastbanshee8 Posted June 19, 2014 Report Posted June 19, 2014 Replace the spark plug boots, check the pick-up gap on the flywheel, and replace the spark plugs. What brand of stator, and cdi did you use? Quote
buckdeezy88 Posted June 19, 2014 Author Report Posted June 19, 2014 Not sure on the stator bought it on ebay and the cdi is ricks Quote
buckdeezy88 Posted June 19, 2014 Author Report Posted June 19, 2014 The tors has been taken off and all unplugged could that have anything to do with it? Quote
fastbanshee8 Posted June 19, 2014 Report Posted June 19, 2014 Anything to do with Ricky Stator is a huge problem. Everything they make is known to be bad from the start, or fail soon after installation. Quote
buckdeezy88 Posted June 19, 2014 Author Report Posted June 19, 2014 Damn I should have got on here before... I bought the banshee like it sits so I have no clue where to start Quote
buckdeezy88 Posted June 19, 2014 Author Report Posted June 19, 2014 Does moose racing build a good stator? Quote
buckdeezy88 Posted June 20, 2014 Author Report Posted June 20, 2014 How can I test to see where my problem is? Quote
wayne_smith97 Posted June 20, 2014 Report Posted June 20, 2014 I will have to look for it but I will get you the specs for the coil and stator. Can't test the Cdi box Quote
