04sheetime Posted June 9, 2014 Report Posted June 9, 2014 I just purchased a stock 03 banshee. Just added toomey t6 pipes and pipe kit. The kit included 270,280 mains, toomey needle, foam filter and 12 air box vents. I installed the vents in the lid and removed the snorkel, put in the 280 mains, needle 4th clip down, and turned the air screw 1.5 turns out. When it was stock it started first or second kick. Now it sometimes starts with a couple kicks but after sitting it can take many kicks. Any ideas on what could cause this? Quote
fastbanshee8 Posted June 9, 2014 Report Posted June 9, 2014 Get some 27.5 pilot jets, and install them. Starting issues are the pilot jets, not the main, or needle. Quote
driftingbanshee Posted June 9, 2014 Report Posted June 9, 2014 Most of the time they will run on a 25 with those but through 1 size bigger then adjust your air screws again. Should be gold dont talk to morons you only educate them.. Quote
04sheetime Posted June 10, 2014 Author Report Posted June 10, 2014 I will try 27.5 pilots and air screws 1.5 turns out. Thanks! Quote
