EaCastillo00 Posted July 14, 2014 Report Share Posted July 14, 2014 or if the bike overheated too bad could also be the cylinder head that cracked and its also letting compression through :/ Quote Link to comment Share on other sites More sharing options...
sootman73 Posted July 14, 2014 Author Report Share Posted July 14, 2014 It was an overheat likely caused by poor jetting and it got out of hand enough to blow the headgasket. Its all back together now, I just need to get the jetting on so i don't have a heat issue again. Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted July 14, 2014 Report Share Posted July 14, 2014 LEAK TEST IT. This is a no-fail task. It isn't too common for people to still be lean with an otherwise overly large main. Quote Link to comment Share on other sites More sharing options...
