I've read that the old hotrod cranks said 204 were stock stroke. New ones are 4mm. The 158 means its got long rods. If the cyls were still on u could measure the stroke and know easily. 54mm is stock. 58mm is a 4mm
Thank you for the info Im trying to figure this out checked the head out and it has been milled but I will know for sure tomorrow when I measure the domes as I am a machinist so I can at least do that. So i could bolt the cylinder back on since they are ruined already. Thanks again.
