quadpro26 Posted April 29, 2014 Report Posted April 29, 2014 DRAG PARTS: 18mm DM complete motor (78 bore, 688cc) $5000 (ask for details) 14mm twister (78 bore, 648cc) complete motor $4000 (ask for details) JJ&A drag axle complete (polished) $450 40mm carrier $75 out left side chrome shear BB/BF (not dm flange) drag pipes $400 out rt side cpi 6 drag pipes (BB/DM flange) $350 rear works shock (red spring) set up for +12 swingarm $400 18mm triple crank (big bearing crankworks billet crank) $1,000 4mm vitos cylinders w/head and domes (70mm bore) needs 1 piston $500cases (w/cut slot, everything still intact) $175 cases (w/chain wack) $125 chrome +13 swingarm $300set of billet PSI "bigair" 42mm alky carbs $500 3- 40mm mikuni tm carbs $375 mattoon billet lockup cover $400 1- mikuni billet bowl (new) $60 shippedcustom painted plastics: candy red w/ghost chains and skulls (front, tank, radiator plastics w/cascade grill) $200HS customs polished grill $75alum insert $15billet handlebar clamp $20chrome v bars $20 stock stators $125 stock flywheels $100 STOCK PARTS: chrome spindles $75 complete rear axle $175 complete stock ign $250 (stator, lightened flywheel, cdi, harness, coil)sprocket hub $30brake hub $15set chrome lower a-arms $75 setset tie-rods (no ends) $15radiator $20rear brake lever $25rear linkage $20chrome sm linkage $25foot pegs $20front hubs w/rotors $30tank $20stock rear spring $10steering stem $30stem mount $5swingarm sleeve $10clutch cover $20 Quote
gordo_dk Posted April 29, 2014 Report Posted April 29, 2014 Can u text me a pic of the aluminum insert? 7608791526 thanks Sent from my iPhone using Tapatalk Quote
srx8525 Posted May 3, 2014 Report Posted May 3, 2014 Do you only have one billet bowl? Pic shows 3 Quote
quadpro26 Posted May 4, 2014 Author Report Posted May 4, 2014 Yeah sold 2 already. I can get another one to match brand new. Both for $120 shipped Quote
quadpro26 Posted May 9, 2014 Author Report Posted May 9, 2014 parts updated, if its up there then its for sale Quote
quadpro26 Posted May 10, 2014 Author Report Posted May 10, 2014 keeping the powerjets, call mike at white knuckle Quote
