ghott Posted April 16, 2014 Report Posted April 16, 2014 Up for sale are some spare parts that I don't need any longer. Most are from an 04/05 Honda TRX450R; many will fit other years or other quads.The prices below include shipping and Paypal fees!I will give a price break on shipping if you buy MULTIPLE parts.Feel free to contact me by PM, by posting here, or by text: 54zero-8four7-247zero. Here are the part's descriptions and pictures:Stock 04/05 TRX450R A-Arms Full Set Uppers and Lowers - $50 - Some of the ball joint stud threads are in very rough shape, the powder coat is also peeling pretty badly - Really only want to get the shipping cost back out of these, Sold as-is - buy at your own riskTRX450R Top Wheelie Bar Mount - $15 - Designed to bolt to 2006+ TRX450R sub frame, may work on other subframes - Heavy, but a very strong wheelie bar mountStock 04/05 TRX450R Ignition/CDI - $11 - Clean piece and in great working condition04/05 TRX450R Demon Industries Billet Resonator Plug - $25 - Nice piece, I bought two of these and only need one, not sure if I even used this one - Paid something like $40 or $45 for it - Does well to clean up the OEM 04/05 intake boot and get rid of the funky resonator hanging off the sideStock 04/05 TRX450R Rear Suspension Dog Bone - $8 - Piece that connects the swing arm to the linkage - Great shape, what you see is what you get04/05 TRX450R Aluminum Front Frame Straps - $35 - Great for drag cut front frames to clean up the look - very light - See picture here to see what they look like installed: http://www.garyhott.com/me_gusta/2014_02_08-04.jpg - Great shape, I only mounted them up but never ran the bike with them - Paid $55 for them a few months ago; only selling because I decided to go with a number plate in the front instead04/05 TRX450R Front Hub Bearing Set - $15 - Good shape - not sure what brand they are tho - Comes with inner and outer bearings and seals for both front hubs - What you see is what you getStock 04/05 TRX450R Front Brake Lines Set - $15 - Good working mechanical condition - Cosmetically, these do have some silver spray paint over-spray on them from previous owner - What you see is what you getStock 04/05 TRX450R Front Hubs Set with Bearings, Collars, and Seals - $45 - Hubs have been primed and painted matte black, great shape - Inner bearings are installed in both hubs (comes with the inner seals and collars too) - Outer bearings, seals, and collars have been removed (so I could scavenge the inner collars quickly) - but the outer bearings, seals, and outer collars will come with the hubs - Not pictured - but brand new, in the packaging, OEM inner collars are included with the hubsStock 04/05 TRX450R Front Rotors Set - $25 - Great working mechanical condition - One of these (on the left in the pic) has a very slight wobble to it but causes very little drag in the caliperStock 04/05 TRX450R Heat Shield for Under Gas Tank - $30 - Great shape with no broken pieces - Both rubber grommets in tact for where the rear plastics attachStock 04/05 TRX450R Piston - $8 - OEM 94mm, 10.5:1 compression, comes with rings, wrist pin, and clip - I have no idea if this is still in spec or not - would make a good paper weight thoStock 04/05 TRX450R Rear Brake Line - $8 - Great working mechanical condition - Cosmetically, its dirty and has silver spray paint over-spray on them from previous ownerStock 04/05 TRX450R Rear Brake Lever - $14 - Great working conditionStock 04/05 TRX450R Regulator Rectifier - $11 - Great working condition - Cosmetically, its dirty and has some silver spray paint over-spray from previous ownerStock 04/05 TRX450R Chain Roller - $FREE - Free with purchase of any other item - This is grooved and has silver spray paint over spray from previous ownerStock 04/05 TRX450R Throttle Cable - $12 - Great working mechanical condition - Cosmetically, its dirty and has silver spray paint over-spray on them from previous owner Quote
ghott Posted April 17, 2014 Author Report Posted April 17, 2014 Front hubs and frame straps sold. Quote
ghott Posted May 5, 2014 Author Report Posted May 5, 2014 Dog bone, brake lever, and chain roller sold. Adding some more parts for sale: Stock 04/05 TRX450R Intake with Cut Airbox - $38 - Great condition - comes with intake, airbox, and snorkel - what you see is what you get - Airbox has been cut to fit big filters (Racers Edge AZ filter) - Intake will be separated from the airbox before shippingStock 04/05 TRX450R Fan - $25 - Great condition - what you see is what you getStock 04/05 TRX450R Foot Pegs - $15 - Great working condition - what you see is what you get - Cosmetically - they are dirty and have some surface rust Quote
ghott Posted May 14, 2014 Author Report Posted May 14, 2014 Throttle? I think I have an extra throttle and cable (stock 04/05 450R) - shoot me a PM if you're still interested. Quote
ghott Posted May 16, 2014 Author Report Posted May 16, 2014 Fan and heat shield sold. Adding throttle/cable, oil cooler, and Yamaha wheels.Stock 04/05 TRX450R Throttle with Cable - $40 - Great condition - what you see is what you get Stock 04/05 TRX450R Oil Cooler - $12 - Oil cooler only - no lines included - Some bent finsDouglas (DWT) Red Label .190 Aluminum Wheels - 8x8 3+5 with Yamaha Bolt Pattern (4/115) - $85 - Great shape - comes with valve stems and red caps as seen - Very strong Quote
