Zacharysalis Posted April 8, 2014 Report Posted April 8, 2014 I just bought an 02 banshee I pulled the seat off and the air filters looked funny so I pulled the covers off and they previous owner and bent the middle in all the way around I was wondering if this could be causing any performance problems Quote
BANSHEE CHAOS Posted April 8, 2014 Report Posted April 8, 2014 I'm assuming they're K&N pods? As long as they're clean, oiled, and intact you should be good. I've had one fall off on the track a couple times and run over it. They're pretty resilient. Better clamps solved my problem. Ideally though bent ain't best. Quote
Zacharysalis Posted April 8, 2014 Author Report Posted April 8, 2014 Yeah they are k&n pods, it's just weird to me they where definitely bent by the previous owner on purpose they both look the same just thought it was strange. Thanks for the reply Quote
special06shee Posted April 8, 2014 Report Posted April 8, 2014 Previous owner probably bent the filters to avoid them from rubbing on frame and wrecking the wire and paper. 1 Quote
