horseman1170 Posted November 13, 2003 Report Posted November 13, 2003 hay guy my shee was running fine i cam out of a burm spiked the gas and it shut down like it was turned off loss of all power in fact thats the first thing i thought my hand hit kill swithch it didnt then it started for about 5 sec then shut down and now it doesent have spark ,tores are dissconected ,new plugs new coil new stator every thing on right and clean ,parking brake blocked off also has commpression enition looks ok and pluged in right could it be the kill switch its self i havent looked any help or insight ,suggestions needed thanks rich Quote
txblueshee Posted November 13, 2003 Report Posted November 13, 2003 Your ground could've came loose on the killl switch......I'd check that real good(p.s. always check the easy stuff b4 you spend 300$ on something that's an easy fix). Mike Quote
wheeleymaster99 Posted November 16, 2003 Report Posted November 16, 2003 it could be your kill switch specaly if you have a teather kill switch the wires could be not makeing a good connectin or something like that Quote
