papersniper Posted April 1, 2014 Report Posted April 1, 2014 Have a fresh top end with just barely enuf time for break in. Stock bore .Wiseco pro-lites. 21cc domes. Vf4 reeds. T6 pipes. "i know they suck but got brand new set for 300$ "stock mikuni carbs. Tors removed. Stock box. lid removed pro flo adapter with K&n filter with outerwear. Currently at 150 and 152 psi. Elevation is from 600ft to 1300ft. Mixing 32:1 with 93 octane. Stock pilots stock needle on 5th clip 1.5 turns out and 280 mains. Bike starts just doesn't wana idle cold . Do i need to up the pilot to maybe a 27.5 or go on to a .30 To cure the idle problem? Haven't really got to open up to get on the main jet because i smoked the clutch within 30 mins after the build. but I'm pretty sure i need to fatten both main and pilots?? Temp is bout 60 to 70 here in middle Tn rite now .Thanks for any input Quote
papersniper Posted April 1, 2014 Author Report Posted April 1, 2014 Sorry for the double post . Phone crashed and thought the first didn't go through. Quote
