gumby Posted November 11, 2003 Report Posted November 11, 2003 will a 94 carrier fit on a 87 and if so is it a direct fit Quote
Holyman Posted November 11, 2003 Report Posted November 11, 2003 I thought the early carrier AND swingarm were different from the later ones. Quote
ledofthezep Posted November 11, 2003 Report Posted November 11, 2003 I think the only thing different is how you tighten them...someone correct me if I'm wrong. Quote
mrmatt Posted November 12, 2003 Report Posted November 12, 2003 The '87 & '88 swingarms and carriers were different than the later model ones. The early ones used four short bolts instead of two long ones to hold the carrier to the swingarm. Also on the older ones, the carrier mounting tabs go on the outside of the swingarm tabs. So the washers that are welded to the upper swingarm holes are located on the outside of the tabs on the earlier models, while the later models have the washers on the inside. To use the old carrier with a new swingarm you will need to add a couple of washers as spacers on the upper bolts. So yes, it is a bolt on, but you'll need to use a couple of extra washers. Quote
gumby Posted November 12, 2003 Author Report Posted November 12, 2003 ok but how about a new carrier with an old swingarm how would that work or would it Quote
mrmatt Posted November 13, 2003 Report Posted November 13, 2003 ok but how about a new carrier with an old swingarm how would that work or would it Whoops, I guess I didn't read you're question carefully. Yea, it will work, but you'll still need to use a couple of washers as spacers. Quote
