BANSHEEBEEFM2M Posted February 11, 2014 Report Posted February 11, 2014 Will it work with a spacer plate? Stock head was modded for the 4 mill with stock jugs. Bore will be 64.5 Sent from my N8000_WHTE_CKT using Tapatalk Quote
sprinklerman Posted February 11, 2014 Report Posted February 11, 2014 Will it work with a spacer plate? Stock head was modded for the 4 mill with stock jugs. Bore will be 64.5 Sent from my N8000_WHTE_CKT using Tapatalk You have a 64.5 cub? Sent from a van down by the river Quote
Nightmare Posted February 11, 2014 Report Posted February 11, 2014 Just listen to what they told you in your're other thread. i've tried it too, it don't work. Get a ss crank or the right cyls. Quote
possum Posted February 11, 2014 Report Posted February 11, 2014 Op do you know what a cub is? serious question. Quote
oldskool Posted February 11, 2014 Report Posted February 11, 2014 I thought 65.00mm was smallest cub bore, then with stock stroke you end up with 358cc Wrong, they show a 64.00mm Quote
