06banshee914 Posted February 9, 2014 Report Posted February 9, 2014 My banshee only starts when i put starting fluid in the spark plug holes and in the intake, without the starting fluid it wont start, any suggestions why? Quote
foxrider603 Posted February 9, 2014 Report Posted February 9, 2014 Starting fluid is no good for 2 strokes. How was the bike running before this problem occured? Quote
Starwriter Posted February 9, 2014 Report Posted February 9, 2014 Compression test, leakdown test, clean carbs make sure choke tube is between carbs, slides in the correct sides, bowls on the correct sides, and check to see what jets are in the carbs. Buy a Clymer manual and do lots of reading on BHQ. Quote
06banshee914 Posted February 10, 2014 Author Report Posted February 10, 2014 It use to start right up a few months ago, i tried last week and it didnt start so i put the starting fluid and then it started and thanks for the advice Quote
foxrider603 Posted February 10, 2014 Report Posted February 10, 2014 Well depends on where you live in the last couple of nonths im sure theres been a temperature difference so jetting might be the issue, or bad gas from sitting Quote
