The top is breaking up
and the bottom sounds flat.
Oem stator and coil
Pickup gap 18
Carbs pwk 28 150 main 45 p
No port stock cylinders, 21 domes fresh gas mix
Pod filters
Passed leak down. Good comp.
I'll post up until successful.
I have found with those carbs needles makee a huge diffrence it it has the silver needle with no markings ditch it and get n68a for stockish motors jjh for modified , if it sounds like its going on a 2 step or ignition break up on top swap coil and sometimes they test good but still are not. Flat bottom can be needle selection jets dont sound that far off with proper needle
