7 mil cub engine
7mil cub engine, ported by k&t, redline/noss head, wiseco pistons, billet twister crank, direct drive lockout, hinson basket, driveline fzr 1000 clutch, pro design water pump impeller, shift shaft mod, shift star mod, shift drum machined for bearing, end cut tranny, pump gas domes from redline, engine is all powder coated, it is still on the quad, if you are local you are more then welcome to come check it out, I can not load pictures, so you can text me for pics, or if someone can let me know how to load pics I would appreciate it, has about 25 to 30 hours on it, the following parts are not included reeds-intakes-stator-flywheel
$3000 shipped
call or text 570-793-7097
