Fresh rebuild, left cylinder missing
jacowils
I will trim the wires and remove the filters are try that and see what happens. Could this be a possible stator issue? When i intially blew it up last summer i had assumed the misfire before i rebuilt the top end was due to there being only 60 psi in the left hole and 90 in the right, but now since the problem has persisted with a fresh top end its leading me to beleive this problem occured before i rebuilt the top end and has nothing to do with the actual internal engine at all and maybe an external source such as a spark issue. Am i right in assuming this or should i reevaluate the situation
