Bushings for your A-Arms are bushings. Nothing special. You can get those and even Needle bearings models….but greasing stuff is the #1 thing to remember. Also, PLEASE use a torque wrench on the bolts and torque them to the proper spec.
Too loose and the support pins spin and also your mounting holes can oval. Too tight and bolts snap.
Wheel spacers are for kids quads.
Do the reverse offset trick on your fronts or buy +2+1 A-arms and get a real rear axle.
