Blanky86 Posted December 30, 2013 Report Posted December 30, 2013 I recently purchased V4, and am curious is there a modification i need to make to them or another part i need to install these i feel like something is missing or should they just go right on? Quote
ginger Posted December 30, 2013 Report Posted December 30, 2013 They go right in, Just double check your jetting afterwards otherwise enjoy Quote
WINDYCITYJOHN400 Posted December 30, 2013 Report Posted December 30, 2013 I recently purchased V4, and am curious is there a modification i need to make to them or another part i need to install these i feel like something is missing or should they just go right on? They are a tight fit. DON'T do any mods…the mods people did to the 3's actually lower performance on the 4's. Put them in and go up one size on your pilot and you'll be pretty close to the sweet spot. (if your bike was dialed in sweet with your last set of reeds.) Play with your airscrew from there. Quote
J-Madd Posted December 31, 2013 Report Posted December 31, 2013 I match the cages or intakes so there is a smooth transition. Quote
Young Guns Racing Posted December 31, 2013 Report Posted December 31, 2013 If you are using stock intakes and never had a set of vforce reeds you will need to cut the "ears" / tabs off of them before they will fit. Other than that they will bolt right in. Windy is right, one suze up on ur pilot jet and go from there. Quote
Blanky86 Posted December 31, 2013 Author Report Posted December 31, 2013 Thanks for all the responses I had stock reeds before so I needed to cut the tab off of them to fit. Quote
