ghott Posted December 23, 2013 Report Posted December 23, 2013 Up for sale are a few 04/05 Honda TRX450R parts.First and foremost - the prices do NOT include shipping and do NOT include PP fees. Buyer will cover the PP fees or can gift the payment to save the hassle. Shipping prices: - Anything that will fit in a USPS Priority Mail small flat rate: - add $6 - Anything that will fit in a USPS Priority Mail medium flat rate: - add $13 - Anything that will fit in a USPS Priority Mail large flat rate: - add $18 - Anything larger than the above will be $25+ depending on box size, weight, and destinationPrices are pretty firm, but will cut you a break if you buy MULTIPLE items.I'm also open to the following for trades: - Set of NICE 04/05 TRX450R front brake rotors - MUST be STRAIGHT - NICE 04/05 TRX450R rear brake rotor - MUST be STRAIGHT - 04/05 TRX450R Drag style light foot pegs - 04/05 TRX450R Rear brake lever for lockout (ATVPartsCentral) - 04/05 TRX450R Dynatek Programmable Ignition (04/05) in good shape - 04/05 TRX450R Stainless Steel Swing Arm Pivot Bolt (new) - 04/05 TRX450R Moose Poly case saver - Black Banshee TM Designs chain guide - 19x6-10 ITP Sand Star front tires on 10x5 douglas blue labels (Honda bolt pattern) - 21x12-8 STU Padla Brat rear tires, comp cut - 9 paddle only - Skat Trak Terrain Trak or Desert Storm Rear Tires Here are the part's descriptions and pictures: - Chain and Sprocket Set (nice set) - $25 -- 13T Front Sprocket -- 38T Rear Sprocket -- 94 Link RK EKW X-Ring Chain w/ Master Link - CP M2035 94mm 12:1 Piston (used for maybe 4-5 hours total) - $65 -- With Wrist Pin, Original Box, etc. -- No clue if this is still in spec - but it definitely should be Stock 04/05 TRX450R Ignition/CDI - $10 -- Works great, just dirty Stock 04/05 TRX450R Oil Cooler (w/ lines, o-rings, shroud, and mounting bolts) - $25 -- Very nice complete set -- Dirty but works great Stock 04/05 TRX450R Top Motor Mounts (complete with bolts) - $5 -- Nice complete set Stock 04/05 TRX450R Radiator w/ Cap - $20 -- She's dirty and has quite a few bent fins; also dented on top-right side -- Still works great and has no leaks Stock 04/05 TRX450R 94mm Piston w/ Pin and Rings - $5 -- No clue if this is in spec or not? Stock 04/05 TRX450R Parking/E-Brake Complete Setup w/ Cable - $5 -- Great shape, little dirty, has silver spray paint over-spray on it Stock 04/05 TRX450R Head Light - $65 -- Comes with mounting brackets and bulbs -- Worked great on high and low beam Stock 04/05 TRX450R Rear Shock - $20 -- Inner plastic shroud is cracked; has silver spray paint over-spray on it -- Functions perfectly Complete Stock 04/05 A-Arm setup w/ Aftermarket (?) Tie Rods - $70 -- Comes with everything pictured -- WILL NOT SEPARATE -- PLEASE NOTE: threads on the a-arm ball joints will need to be cleaned up -- Worked well, just removed - ball joints are tight, boots are in good shape -- Tie rods look like they are aftermarket - pretty thick and strong -- Also comes with the brackets for the brake line mounts -- Do NOT come with frame mounting bolts, spindles, or hubs -- Lots of scratches on these, but they are straight Handlebars - $15 -- Comes with everything pictured -- No clue what brand they are - possibly the brand pictured on the foam cover -- Stock thickness -- Comes with grips Quote
ghott Posted December 24, 2013 Author Report Posted December 24, 2013 CP Piston, Chain/Sprockets, and Top Motor Mounts are sold. Quote
ghott Posted December 31, 2013 Author Report Posted December 31, 2013 Radiator and rear shock sold. Quote
