Thinking of building a motor
tdod101
I have the urge to build a badass motor from the ground up, I wanna keep using the one I have so I can still ride. I wanna buy all the parts I need from HQ members,
Basically start off with the cases clean them up and figure out what I wanna do with it.
What do you guys think ? Which direction should I go. I'm in no rush so I can definitely take my time, also I would like to stay on pump gas but IF I have to buy VP race fuel I suppose I can
i say extend your frame a couple feet and put a rotax 583 in it. BADASS
No thx lol
Well I can spend money over time, I would say I want to spend around $2000 - $3500 over time just on the motor.
As for expectations I don't know, you tell me. The faster the better I suppose
800 cylinder + possible 350 for porting
450-500 crank with bearings
200 for case
400-600 modded trans with new bearings
300-400 for clutch setup
350 for pistons n gaskets. plugs n extenders
280-300 for cool head and custom domes
500-700 for pipes.
350 for carbs.
500 for just in case.
:shrugani:
  • Like 1
So more like 5 g's
Yes. That'll get you what you want with out settling when you start coming up to your max. So if you want this for 600 but your 1k away from you budget and your only half way done, you won't settle for the 300 one that's half as good. So 5 is a good budget with a lot of cushion room.
