olympicgold1 Posted December 17, 2013 Report Posted December 17, 2013 OK so I just got through another problem and now its only running on the left cylinder. I pull the right plug and its all wet and clean. The choke tube is on ok and I just rebuilt the motor so I know the head gasket is ok, but for the heck of it I removed the head and put silicone on the gasket and retorqued. I tried running it for a little without water just to be sure it wasn't a head gasket but still only left cylinder runs. I took off the right pipe and carb and ran it dry. I would then put the right carb near the intake boot and fuel would flow into the cylinder and the right cylinder would begin to pop but as soon as I pushed the carb in it would stop and the plug would get wet again. Brand new plug too, tried swapping it with the left as well as the plug boot but still only the left cylinder works. So what do you guys think Quote
tdod101 Posted December 17, 2013 Report Posted December 17, 2013 I'm sorry but I couldn't decipher what your trying to say, you put water in the engine ? Quote
sstaton1983 Posted December 17, 2013 Report Posted December 17, 2013 (edited) What"s the compression? Also check to see if the main jet is laying loose in the bowl. Edited December 17, 2013 by sstaton1983 Quote
olympicgold1 Posted December 17, 2013 Author Report Posted December 17, 2013 I feel dumb saying this but the pilot jet came loose in the bowl......SSTATON almost had it!!! Quote
Young Guns Racing Posted December 18, 2013 Report Posted December 18, 2013 Happens to lots of us. Glad u got it solved! Quote
