most right alky domes are a lil less comp and more mild of a velocity setup.   most gas domes in cubs are either really loose to make them live  or really tight for performance and who cares if they blow up clearance.  usually a few simple squish tests will tell you width and clearance.  on gas 50+ clearance and around a 10mm band width max would run ok.  there are a lot of other variables but in simple terms that should be ok.  you can even start at 0 timing and work your way up checking plug strap color with each change.
