Sounds like your going to get the same answer here too. I think alot of the clutches are made of similar material. The springs you use will make a lot of difference. I choose the barnett dirt digger. Someone on here said the EBC shattered on them a couple times and didn't have any trouble with the barnett.
The pull on the barnett is harder because they use heavy duty springs. Banchetta swears by his duncan clutch. It cost more, but he says the pull is as easy as stock. It's your $$$. Choose wisely grasshopper :ph34r:
