I bought a banshee and the carbs don't fit the stock boot.. The outside of the carb measures 40.94mm. I pretty much needs these to finish my build anything will help. Thanks
They are keihin flat slide carbs. That is all I know I bought this thing and now I am peicing it back together. They are obviously way bigger then the stock intake boot.
Trying to upload pics its not working.....no stamp it's says keihin Japan where yours says pwk but on the flat part right below that it says pj.
There you go man it's a 34 mm carb And I have the intakes you need to make them work
Shoot me a p.m. if you're interested
And just so you know Stock carbs are 28 mm Mikuni's So I hope you have a little motor work done to your bike To compensate for the size of your carbs
