I bought these a few weeks ago hoping to use them on a 10DM.  I spoke with a couple builders, and as it turns out, they will require WAY to much work to make that happen.
Specs:
-102mm spread
-Small bearing (62mm)
-Deck height is stock, I believe.  If someone with more knowledge knows otherwise, let me know.
-Trenched for 18mm
-Top case has been setup for Twister cylinders, and expoxy has been used, as seen in the photos.
-Stator side of top case also has epoxy near the top where the cylinders sit in the case (see photo)
-MOST of the hardware is included which hold the two halves together from the underside of the case, cylinder side.  -Hardware IS needed for the transmission side.
These could be a deal for someone, they could be made to work with other cylinders, but a FUCK of alot of welding would have to be done.  I was going to remove the epoxy and weld them back up myself, but the post machining time would be a killer, at that point I might as well buy new cases.
Price: $925.00, shipped.
Pics:
Price: $925.00 shipped
