LowlyOilBurner Posted September 24, 2013 Report Posted September 24, 2013 I bought these a few weeks ago hoping to use them on a 10DM. I spoke with a couple builders, and as it turns out, they will require WAY to much work to make that happen. Specs: -102mm spread -Small bearing (62mm) -Deck height is stock, I believe. If someone with more knowledge knows otherwise, let me know. -Trenched for 18mm -Top case has been setup for Twister cylinders, and expoxy has been used, as seen in the photos. -Stator side of top case also has epoxy near the top where the cylinders sit in the case (see photo) -MOST of the hardware is included which hold the two halves together from the underside of the case, cylinder side. -Hardware IS needed for the transmission side. These could be a deal for someone, they could be made to work with other cylinders, but a FUCK of alot of welding would have to be done. I was going to remove the epoxy and weld them back up myself, but the post machining time would be a killer, at that point I might as well buy new cases. Price: $925.00, shipped. Pics: Price: $925.00 shipped Quote
LowlyOilBurner Posted October 2, 2013 Author Report Posted October 2, 2013 Open to reasonable offers. Quote
