I'm not well-versed in the area of drag wheels or tire sizes so I'm hoping a few members with some experience can help me out.
Douglas .125 aluminum blue label REAR wheels...if one is drag cut - what is the approximate weight savings over a non drag cut blue label?
For those that have purchased drag cut wheels before - is Sand Toys the best place to purchase?  Do the Sand Toys wheels come with valve stems installed?
And lastly - is there any reason NOT to run a 21x12-8 (Padla Brat) or a 22x11-8 (Pro Wedge) on an 8x7 rim vs. an 8x8 rim?  I'm wanting to go with an 8x7 rim size to try and save even more weight but I'm a little concerned that it might not be wide enough for the tires in question?
jd said the paddla brats are also wider than a normal tire like skat trak or something, so i dont know if that would mean you would want to run a wider wheel also.
