I just picked up a 535 cheetah that was drag ported by k&t and was ran on c12 gas. I want to convert it to alky for 1/8 mile asphalt. It has a one piece head with non removable domes.
The squish was around 37 thousands with a 22 thousands base gasket. Can I run alky with the current domes and that tight of squish.
If titan cut me new domes what squish and compression range should I aim for? The current setup ran 128mph in the 1/4 mile
Probably gonna need to know the squish band width and final compression ratio to figure out to mention dome profile shape.
Tim will know based on what you want to do. He will need some measurements from you though like piston,rod,stroke,cyl height,deck height. then he can cut what ever you want. if you degree it before tear down you can adjust timing if needed with the base gasket. i have a head shell id sell if interested lmk.
  • 2 weeks later...
Well learn something new everyday. I had the old style head on my set up. And bought the DM style a few years back.
Sent from my DROID RAZR using Tapatalk 2
