quadpro26 Posted July 5, 2013 Report Posted July 5, 2013 DRAG PARTS: 10mm supercub topend w/head and domes(fresh nikel and new pistons) $10004mm vitos cylinders, pistons, head w/domes, 4mm crank, cases $1000 18mm billet crank, DMX cylinder (needs pistons and coating) $1100 4mm cub cylinders, pistons, w/coolhead $900 4mm stock cylinders (pistons, cylinders) $300 4mm crank (LR) $300 coolhead $125 35mm billet intakes $75poilished cases (no wack) $250cases (w/chain wack) $125cases (no chain wack pc'd black) $200cases (w/out hain wack) $200 DD spindle mount w/tires $325set of billet PSI "bigair" 42mm alky carbs $500set of 40mm alky kehin PWK $3752-5 over-ride tranny $300 rear Marvin shaw (stock length) $125straight cuts w/Hinson basket $340 hinson basket $120lock-up $50Kehin 34PJ carbs $200(3) mikuni 40TM carbs $300 mikuni billet bowl (new) $60 shippedcustom painted plastics: candy red w/ghost chains and skulls (front, tank, radiator plastics w/cascade grill) $225HS customs polished grill $75alum insert $15billet handlebar clamp $20chrome v bars $20set of solid adjustable struts $60 chrome LSR (sport series) +2 a-arms $325 +8 LSR chrome aerotube swingarm $350 STOCK PARTS: a-arm frame (powder coated candy translucent blue) w/title $350 rear shock (w/candy blue spring) $100 complete stock ign $250stock tranny $110sprocket hub $30brake hub $15set chrome lower a-arms $75 setset tie-rods (no ends) $15radiator $20complete front brake assy (new style) $60rear brake lever $25rear linkage $20chrome sm linkage $25foot pegs $20front hubs w/rotors $30tank $20stock rear spring $10steering stem $30stem mount $5swingarm sleeve $10clutch cover $20 OTHER: 130/70/19 knobby tire $30 110/90/19 paddletire (pretty used) $20lots and lots of stock parts, so if your looking for bolts, brackets, ect just ask. Quote
LT ROOKIE Posted July 5, 2013 Report Posted July 5, 2013 If the 10mm crank is billet and in good ready to run condition I will get it. Quote
banshee760 Posted July 5, 2013 Report Posted July 5, 2013 Is that a hybrid frame? ? And does it happen.to have payper work? Quote
Badbrad81 Posted July 6, 2013 Report Posted July 6, 2013 Hey would u take 350 four the three 40mm carbs an the billet bowls Quote
quadpro26 Posted July 6, 2013 Author Report Posted July 6, 2013 not a hybrid frame. Its a complete chassis. Bill of sale comes with it Quote
quadpro26 Posted July 6, 2013 Author Report Posted July 6, 2013 all questions and pm's answered Quote
LT ROOKIE Posted July 6, 2013 Report Posted July 6, 2013 What about the 10mill crank? Is that the billet crank in the picture? What size rods? Quote
quadpro26 Posted July 7, 2013 Author Report Posted July 7, 2013 burgandy painted ones still available 1 Quote
