I have a stock banshee , stock port and bore, with k&n pods no box TORS removed , fmf sst pipes. The problem is the bike bog when i want to take off unless i give it a ton of gas, bike idles fine and revs fine when in neutral , but when i clutch it to take off it wants to die down. My current jetting is 27.5p and 300 m with 1.5 turn af
i would say you are either getting to much fuel or not enough fuel get yourself a 25p and 30's see what work the best. i gotta stock port bord 60 over with the sst's hooked up and am running 30p with 290 m. my only probloem is in high rpms and it backfires every once i awhile think im going to jump up to a 300 also
plugs might not show up wet because your mains are good and burn the acsess off during high speeds, the pilot and air fuel mixture are what would control idle to 1/2 throttle actully just before,mains are only from 3/4 to full throttle
