atcandbanshees Posted June 16, 2013 Report Posted June 16, 2013 I have a bunch of parts laying around I'm not going to use on my bikes I would like to trade or sell make reasonable offers if wanting to buy. Everything is in good working order just not what I'm looking for on my bikes. If u need a part not listed i might have it between me and my friends so just ask if u need some thing. I can text pics of parts if your interested pm me your number or text me 2532619196 Shearer big bore in frames chrome only couple rides on them CPI big bore inside stamp pipes and cascade center mount silencers one has chain rash but in working order Toomey t3 pipes and silencers some rust and cracked hangers and couple dents Wicked atv silenced out the right drag Pipes with egt ports Sls 16.5x4 smooth buff tires on 10x2 banshee spindle mount solid polished wheels 250r lone star drag axle polished with rotor and carrier And brake plate Full front brake setup with stainless lines 4 sets of stock cylinders Stock heads Two transmissions 3 stock cranks need bearings or rebuilds 2 Complete pvl ignitions Billet basket straight cut gears some wear came from a running bike Polished lockup cover and lockup solid no window with water pump and polished cover 2 Polished clutch cover inserts 2 boost bottles 3 sets of Reed spacers 38mm pj carbs Twist throttle and cable was on 39 keihins 35mm billet intake 28mm billet intakes Trinity 2 into 1 intake needs new intake boot Stock mod air box with pro design kit installed k&n and putter wear Polished stator cover White knuckle 4mm cub domes for white knuckle head Complete chrome axle with all the hubs chrome also and polished lock nut Couple sets of hubs Stock rotors Chrome j arms some rust Couple random a arms Stock shocks 2 sets swingarm Rear linkage Tie rods Fender supports Stock front brake lines White rear chain slider Used chain sliders red front and yellow set Polished throttle cover Easy push thumb throttle Pingel billet tether kill switch Polished handle bar clamp new in the package Hs customs flaming skull grill Black stock fenders shaved front full rears Stock radiators Couple sets reeds one stock one aftermarket in stock cages Stock intake boots 3 stock parts carbs Two key switches new style Stock fuel valves Quote
atcandbanshees Posted June 17, 2013 Author Report Posted June 17, 2013 Stator cover case saver and round carrier and brake plate sold Quote
atcandbanshees Posted June 17, 2013 Author Report Posted June 17, 2013 Thing I need are Sb sf inframe pipes Small flange out the left silenced shearers Aluminum axle for banshee Aftermarket jarms Aftermarket aarms Coolhead 35or bigger pwks Mint condition cases Rear Marvin shaw Extended swing arm Ims pegs Drag cut seat Quote
atcandbanshees Posted June 26, 2013 Author Report Posted June 26, 2013 Red chain slider Lockup cover One set of cylinders One set of tie rods sold Still got lots of parts forsale or trade Quote
dannyjr985 Posted June 27, 2013 Report Posted June 27, 2013 what do you want for the 35mm intake and boots Quote
BANSHEEBEEFM2M Posted June 28, 2013 Report Posted June 28, 2013 Ill give u a set of lsr +2w +1fw a arms with tie rods for a set of pipes Quote
atcandbanshees Posted June 28, 2013 Author Report Posted June 28, 2013 16.5s? 35mm intake sold locally Quote
bluepartsman Posted July 3, 2013 Report Posted July 3, 2013 (edited) I can do a partial trade cool head that I have for those BBshearer IF pipes you got? Edited July 3, 2013 by bluepartsman Quote
