whoppes27 Posted June 11, 2013 Report Posted June 11, 2013 Looking for a little help with my chassis setup for 300ft. Here is the bike info: Stock lightened chassis ~300lb +2 forward arms +12 swinger/ no wheelie bar 14p ext 22" 180-185lb rider 421 alky cub drag port/ oof estimated 100-110hp I think my 60ft is killing me. I've ran the bike a best of 4.1's that was with 1.5 60's and 16/43 gearing. This year I've been averaging 1.6-1.7 60's and 4.3's. Same track, not sure if they've changed anything. I've tried 15/42 gearing and currently at 16/42, I've also tried different air pressure and my 60's and et does not change. I feel like I'm blowing the tires off. My thought is to ditch the +12 swinger and go to maybe a +10 or +8 with a bar. Just wanna make sure I'm on the right track. Any suggestions are appreciated. 1 Quote
J-Madd Posted June 11, 2013 Report Posted June 11, 2013 Sounds like it might be in the clutch, fibers maybe worn or steels warped. I also would recommend a bar and set the swingarm at -6 degrees. Quote
Fastassbanshee96 Posted June 11, 2013 Report Posted June 11, 2013 -6 degree on swingarm? Can you explain? Quote
fappy'97 Posted June 11, 2013 Report Posted June 11, 2013 (edited) -6 degree on swingarm? Can you explain? The angle from the axle to front sprocket shaft. Edited June 11, 2013 by rappy'97 Quote
whoppes27 Posted June 11, 2013 Author Report Posted June 11, 2013 Haven't pulled the clutch pack yet but I wouldn't be surprised if it was toast. Its been in there a while and that would make sense why gearing/air pressure isn't changing my 60's or et's. Does the swing arm sound too long or you think its fine if properly set up with a bar? Quote
Fastassbanshee96 Posted June 11, 2013 Report Posted June 11, 2013 So you want it to be a minus 6 degrees? Wouldn't that put an upward rake on the swingarm? Meaning that the swingarm would have to travel higher than the sprocket.... Or am I just reading this wrong. Quote
J-Madd Posted June 12, 2013 Report Posted June 12, 2013 + 8 swingarm with a bar and 14 paddle 72" RO extremes will help a lot. Should get some 4.0s if you weigh 185 lbs or less. Quote
whoppes27 Posted June 12, 2013 Author Report Posted June 12, 2013 got the paddles, just need the arm and a bar. the old owner ran a few 3.9's out west with it so I would love to see a 4.0 with me on it. I have a new clutch pack on the way. Thanks for the help. Quote
10dmbanshee Posted June 12, 2013 Report Posted June 12, 2013 On our 7 mill stock Cyl bike we ran several 4.0s n its a +13 arm. But the hole bike ready to race was 270lb with 180lb rider. With 1.40s 60 ft. You can make a long arm bike work.setup is key Quote
whoppes27 Posted June 12, 2013 Author Report Posted June 12, 2013 what paddles were you using with that bike? Quote
J-Madd Posted June 12, 2013 Report Posted June 12, 2013 + 8 swingarm with a bar and 14 paddle 72" RO extremes will help a lot. Should get some 4.0s if you weigh 185 lbs or less. I meant to say staggered extremes. We picked up half a tenth from the straight paddles. 8x9 wheels help too. Quote
10dmbanshee Posted June 12, 2013 Report Posted June 12, 2013 73 ro 14 staggered extremes on 12x12 wheels Quote
J-Madd Posted June 12, 2013 Report Posted June 12, 2013 73 ro 14 staggered extremes on 12x12 wheels That's one way to get it done. I'd be interested to see those tires and wheels. Sounds like RDZs setup a few years ago. Did you have an air shifter and foot pegs on the swingarm? Probably not, just asking. Quote
10dmbanshee Posted June 12, 2013 Report Posted June 12, 2013 I'll get a pic of tires n wheels. No swingarm foot pegs. Its Jordan rowan from turbo chassis the stock frame they had their turbo motor in Quote
J-Madd Posted June 13, 2013 Report Posted June 13, 2013 I know the chassis. What's he got the turbo on now? Quote
