Aaron109 Posted June 3, 2013 Report Posted June 3, 2013 I have an 03 I believe but it's starting to mix the antifreeze with the gas what's the problem??? Quote
Aaron109 Posted June 3, 2013 Author Report Posted June 3, 2013 Wait no he said its mixing the antifreeze with the oil sorry Quote
rg97 Posted June 3, 2013 Report Posted June 3, 2013 The water pump area is separated from the transmission by a seal and bearing, maybe the seals bad Quote
sheerider11 Posted June 3, 2013 Report Posted June 3, 2013 The water pump area is separated from the transmission by a seal and bearing, maybe the seals badid lean more towards the o ring on the little tube that sticks out of the cases Quote
Aaron109 Posted June 3, 2013 Author Report Posted June 3, 2013 So do I have the split the cases to fix this problem? Quote
