double gasser
I have one and I like it a lot. I use it 80% thumb and 20% twist. It could be better, but it does work good. The thumb travel is a little slower than I like. In other words, from idle to wide open, you have to push it too far. The twist is very fast. The worst problem is that you can't pull the pin to unlock the twist while riding. I plan to fabricate a lever that you can flip with your index finger.
