compression verses timing
mx1986
Wow! 17cc domes on a 10 cub at 1k elevation. That will put you around 18.6:1 UCCR. I set mine up with 20's at 4500' assuming a cub with std deck heights. You've got way too much compression IMO. You'd be much better off to go to a larger dome and less compression. High compression motors can and will fight themselves in the higher RPM's. As you approach the peak efficiency of your pipe/porting the dynamic compression will dramatically increase well above cranking pressures. To much static compression will kill the motors ability to over-rev and can slow the motors acceleration.
