So im working on my uncles shee and it has no spark so I put in my working spare coil still no spark so I put in a working stator still nothing so I pluged in my cdi still nothing any ideas I cant see any damaged wires clueless need help asap
Yep still bad and checked at cdi plug for that as well black and blk/wht and its open as well. How do you eliminate on off switch next time ill try ill elim that and key and see if I get better result
So if I unplug light/kill plug and blk/w wire ir will still start
Correct, but you still need to find out why there's no connection between the red/black wire and the black wire. That's your problem.
