houghkyle Posted May 15, 2013 Report Posted May 15, 2013 06 banshee, CPI small bore, 64.5 bore, milled head, race port, +4 timing, K&N in box and lid off, and lightened timing. I am running 350 mains and 32.5 pilot. 1300 ft elevation. Bike runs good and starts good but it seems like it get really hot quickly. Quote
BUILDER Posted May 15, 2013 Report Posted May 15, 2013 If it is getting hot quick I would check the water pump and also check for a air leak becasue your main jet is plenty big for that motor! Quote
houghkyle Posted May 15, 2013 Author Report Posted May 15, 2013 If it is getting hot quick I would check the water pump and also check for a air leak becasue your main jet is plenty big for that motor! I did a leak down test and it was good. Whats the best way to test the water pump? Would you suggest I step down on my mains? Quote
houghkyle Posted May 15, 2013 Author Report Posted May 15, 2013 It also seems to bog pretty bad until it hits the band. It is almost like I have to be WOT everywhere I go or it tends to bog down. Quote
