Anthony133 Posted May 14, 2013 Report Posted May 14, 2013 EVERYTHING is in good condition unless otherwise stated, some parts need cleaning. Came off a 2000 and 1999 Banshee All prices are shipped Heres what i have: Tie rods-$30 Top bar clamps and bolts-$15 Footpegs ( Bare Metal)- $30 Steering stem clamp with wire retainer and bolts-$20 2 wire Ignition and bar mount-$35 Handle bar support-$20 Rear suspension linkage with bolts and bearings- $30 axle drum-$15 Steering stem bearing retainer nut-$5 Coolant bottle relocator bracket with bolts-$25 2X parking brake cables-$15 each Clutch cable-$15 Yellow front shock-$20 Gas tank with cap, petcock,metal grommets-$50 2X carrier bearings- feel great-$15 each Fuel lines( tank to carbs)- $10 Carb tube- goes in between carbs-$5 Rear brake pads- good condition-$10 Axle nuts-$10 1 exhaust hanger-$10 Rear axle hub castle nuts and washers-$10 14 a arm bearing caps-$10 NEW needle seat and valve-$10 stock grill-$10 Tank shroud-$25 Call, text or PM me for pics and questions Call/Text 708-224-8659 Quote
jbmason Posted May 14, 2013 Report Posted May 14, 2013 If the exhaust hanger is for the front and is in good shape i want it. Quote
