I keep reading that the serval goes flat at 9500 rpm. So where does the stock cylinders peak with shearers and dune port? Are t5 a good match for serval cub
Second question if running shearers pipes what is the best match for a dune bike on pump 91. Cub? Wampus? Stock ported ?
here we go with this again.... as i rider i have neer ridden a stock ported cylinder that had the low end power (easy to ride) power like the serval i had... then again i did go with the 472 super serval wampus lol
Keep your hjr 4mm and put shearers on it. Unless you feel like buying a serval and port it in one shot.
T5s on servals suck.
Hit up a sponsor, to get the best out of pump gas you need custom domes.
Cheetah cub and wampus are basically the same, unless you get the serval port timed wampus.
I think my 4 mill is plenty for glamis deep tight bowls. I'm always hitting the brakes to not fly off the edge. But if there is better low end with descent top ill try it.
