tdod101 Posted April 25, 2013 Report Posted April 25, 2013 Putting the carbs back together I forget which slide goes into which one, when looking at the intake side of the carb does the slide with the flat bottom go in or the D shaped bottom go in Quote
sheerider11 Posted April 25, 2013 Report Posted April 25, 2013 The notch/ cut out faces the air box Quote
sprinklerman Posted April 25, 2013 Report Posted April 25, 2013 Putting the carbs back together I forget which slide goes into which one, when looking at the intake side of the carb does the slide with the flat bottom go in or the D shaped bottom go in The cutaway of the slide faces the air filter side. Quote
