I just now had my top end rebuilt and bottom end freshened up . Now I purchased my base gasket from Eastcoast Atv , but that base gasket is green colored and is made out of a material rubber/paper like . I don't know if the gasket is not torque or tightened down enough . But I like the stock Yamaha banshee base cylinder metal gasket . Out of the 2 gaskets which one seals better ?An I have another leak around my engine clutch side caseing . I brought 9 new screws for the clutch side casing , the screws have hex head . An I also have brought lock tight glue, washer locks and high temp rtv glue . For the clutch side caseing. An I also have a leak around my Vito's billet cool heads . It's leaking threw the screws . But I think my mechanic has to tighten the heads screws all down. What do you guys think?
