banshee07 Posted April 13, 2013 Report Share Posted April 13, 2013 I have a shee with a 4mill stroker and bored out a bit to make it a 400cc. I see alot of guys running different carbs on stock shees with a few small mods and done up shees,wondering y guys switch them out? i can see on a way bigger motor for more fuel but y on the 350-400cc ones,what advantage? thanks jeremy Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted April 13, 2013 Report Share Posted April 13, 2013 People think bigger is better. If your motor was fully ported you could see improvements if you moved to a 28mm flat slide carb or into a 30-33 size. But stockes can make 70+. So when you see guys running 34-35mm carbs on a bolt on machine. It's not helping. The only real plus is aftermarket carbs are easier to make jetting changes. Quote Link to comment Share on other sites More sharing options...
banshee07 Posted April 14, 2013 Author Report Share Posted April 14, 2013 Ok so with my ported 4 mill 400cc its prob not worth the money? I dont find it that bad to jet the factory crabs. Quote Link to comment Share on other sites More sharing options...
