Silver bullet shee Posted March 23, 2013 Report Posted March 23, 2013 So I bought this shee a few days ago and the guy said the lights were working and then just stopped. Has trail tech headlights. Well after looking at the wiring the headlights have a green wire to them that's not hooked up. And there are 5 connections under the gas tank that are unhooked. All wires running into these connections are black, black/yellow or yellow/black.and connectors are filled with silicone. And have no brake light either. Any ideas? Quote
vulvafan537240 Posted March 23, 2013 Report Posted March 23, 2013 Those wires are for the tors which you don't need. Ohm out the lighting coil to see if its open or shorted. Could also be the voltage regulator or dimmer switch. Quote
Silver bullet shee Posted March 23, 2013 Author Report Posted March 23, 2013 What exactly is the tors? Only thing I know is it seems everyone hates them Quote
vulvafan537240 Posted March 23, 2013 Report Posted March 23, 2013 Tors = throttle override system. Biggest hunka junk ever. It's supposed to limit rpms if the throttle sticks but it usually fails and limits spark so that it will only idle. Quote
Silver bullet shee Posted March 23, 2013 Author Report Posted March 23, 2013 10-4 thanks ill look into the regulator and switch once I get home Quote
Silver bullet shee Posted March 23, 2013 Author Report Posted March 23, 2013 No not yet but I do have a check light Quote
vulvafan537240 Posted March 23, 2013 Report Posted March 23, 2013 Check light wont read resistance so you won't be able to ohm out the lighting coil but you can check the voltage coming out. Quote
Silver bullet shee Posted March 23, 2013 Author Report Posted March 23, 2013 Guess ill have to pick one up. Thanks Quote
Silver bullet shee Posted March 23, 2013 Author Report Posted March 23, 2013 Anyone happen to know what the green wire is to the headlights? Quote
vulvafan537240 Posted March 23, 2013 Report Posted March 23, 2013 Green and yellow are for high beam and low beam. Tt lights only have high so you leave one wire off for them. Quote
