  • 3 weeks later...
Got the bike running it was 50 ish degrees out and I got 25 pilots 300 mains and it idled the night I started it. Next day I went out to ride and it wouldn't idle and was only firing off one cyl.The other cyl was firing intermettmently. Swapped plug wires and the prob stayed on same side. Also I synced carbs and all. Hoppfully I can change the plugs and test a few things. Pull the non firing side carb and check float and all. And I think ill try a 27.5 pilot since its gotten warmer out and see if it will work.
