4GivenByGodsGrace Posted March 12, 2013 Report Posted March 12, 2013 like the title says, went out this past weekend riding. I heard a jingling sound before the bike cut off and wouldn't start back up. I tried to kick started a few times, and i felt the kick start kicking back to me??? at first I thought it was a fuel problem, so when I got home I took off and clean the carbs, put them back on, and try to kick start it again only to hear the jingling sound when the motor try to crank up. I've done a bit of searching in heaven can come up with anything, except for maybe acrank bearing ?? anyway they have the bike in my shop and I'm starting to tear it apart to pull out the motor, just wanted to know if anyone had any ideas? if I rebuild it I wanted to do a4 21 serval motor, but was also curious about the 4 mil motor E.C. Atv cells already built minus the carbs for 1500 bucks?? I'm assuming that is a short rod 4mil,and has a off brand 4mil crank?? I haven't called about it to ask questions yet, but have done a search to check on the feedback for EC ATV,which some ppl love em,others have had horrible expieriences with them... Any ideas on my rambling post?? Hope i dont get roasted for noob questions,lol. Thanks in advance fellas!! Quote
Starwriter Posted March 12, 2013 Report Posted March 12, 2013 Sounds like the flywheel came loose. Pull the stator cover and check it. Quote
4GivenByGodsGrace Posted March 12, 2013 Author Report Posted March 12, 2013 Ok, i will check that out now onmy lunch break. Thanks Quote
4GivenByGodsGrace Posted March 12, 2013 Author Report Posted March 12, 2013 http://i293.photobucket.com/albums/mm66/mazdadna/CAM00147.jpg Ok took off left side cover and found this.. I dont have the tool to remover rest of it. But as you see the brass hair was everywhere, and the little box with 2 cables on lower pic was broken at tabs and dangling.. Quote
Starwriter Posted March 12, 2013 Report Posted March 12, 2013 Yep, that would be a loose flywheel. You're not gonna need a flywheel puller to get that flywheel off. Hopefully it didn't damage the crank taper. If the taper on the crank and flywheel look good, lap the flywheel before you put it all back together. Quote
4GivenByGodsGrace Posted March 12, 2013 Author Report Posted March 12, 2013 Pickup to i tried to take off the 17 mil bolt but i will need the tool to hold it from spinning. Also all the brass got tangled was just floating in cover, what would need replaced since that "pickup" or whatever it is got broken at tabs? the whole assembly? Quote
4GivenByGodsGrace Posted March 12, 2013 Author Report Posted March 12, 2013 My phone is crazy, disregard the first 2 words above in reply. Quote
apeik Posted March 12, 2013 Report Posted March 12, 2013 An impact airgun is a great way to knock them loose if you have one Quote
Starwriter Posted March 12, 2013 Report Posted March 12, 2013 Pickup to i tried to take off the 17 mil bolt but i will need the tool to hold it from spinning. Also all the brass got tangled was just floating in cover, what would need replaced since that "pickup" or whatever it is got broken at tabs? the whole assembly? Just hit it with an impact wrench. If you don't have an impact, people on here have used a strap tool, or a flat bar with 2 holes drilled in it and bolts in the holes to go into the holes in the flywheel.Make sure the bolts don't go too far in and hit the poles on the stator. I don't know if you can buy a good quality pickup coil. Might have to get a whole new stator. Quote
Zillaguy Posted March 12, 2013 Report Posted March 12, 2013 Imapct is the easiest way to loosen and tighten that nut... Just be careful not to over tighten it, just a couple small burps w/the impact and it will be tight. Quote
4GivenByGodsGrace Posted March 12, 2013 Author Report Posted March 12, 2013 Ok, the impact along with oil filter chain wrench covered with a rag did the trick. But to remove it is another story, i tried gently prying as i turned it without a bit a luck, any ideas? Quote
sheerider11 Posted March 12, 2013 Report Posted March 12, 2013 Buy the 12 dollar flywheel puller Quote
Starwriter Posted March 12, 2013 Report Posted March 12, 2013 OK, soooooo.... If the flywheel doesn't just fall off, you may have much bigger problems. You need to figure out how the flywheel hit the pickup coil. Did the pickup coil come loose or are the crank bearings trashed? Do not try to remove the flywheel with anything other than a flywheel puller. Quote
4GivenByGodsGrace Posted March 12, 2013 Author Report Posted March 12, 2013 As im looking at it I cant see how it was broken, weather a screw came loose or what not. is that a special puller that I should order from a site sponsor or can I find a universal one at a car parts store. Also how do I tell if the crank bearings are bad? Quote
