I have had a problem with losing power on my right cylinder. I checked it and checked it and just couldn't find what the problem was. I changed out stators, flywheels, coils, wires, plugs, cdi box, reeds, carbs and i recently put a totally brand new top end ( new cylinders, pistons, domes, head, gaskets, and even changed out the crank seals too and the problem still persist.
Can you guys let me know what you guys think it might be
I had a set of bored out and trail ported stockers 65mm with vitos super stocks and a 36 pwk and now i put a aet of drag ported 66 jugs with a set of wiseco pistons and a 39 and nothing
I traded the cylinders but the pistons are brand new and i had the cylinders honed. The head is brand new as well as the domes and all new seals and gaskets
replace plugs again and check ground at the coil. your going to have to go over it again till you find it. also whats compression? your runing a single carb? also what is your pickup gap? is it oem stator and cdi??
Comp don't know as for the gap i have always left term the way they come in the box and cdi box i have a stock one and a aftermarket procomp one and stator is a ricky stator
How much does the ricky stator help or what's the difference? Anyone know?
Stay away from Ricky Stator, stick with OEM.
Sent from my SGH-T679 using Tapatalk 2
well then you have missed something because your saying you replaced everything. did you try all oem electronics?
