Stock motor fmf fattys pro design filter no lid. Im in iowa at about 20°- 40° it had 300s in it and I thought itd need to go up. I was wrongvso I put 280s in it seems ALOT better and runs great now. Anyone think its too lean or am I good where im at?
Sent from my SCH-R950 using Tapatalk 2
Seeing that it's cold out, it's very unlikely you are lean. However, you could have a small air leak and not even know it. Do a plug chop, it's the only way to be sure. Just do a plug chop now, then do probably 2 more as the weather warms up. That way you'll know what jets you need for what temps. As you found out, colder weather needs a smaller main, warmer weather needs a bigger main. Keep that in mind so you don't get lean later on. But like I said, plug chop is the only way to go
